changing fuel filter 98 24 valve.
Old Nov 13, 2012 | 08:44 PM
rodnok's Avatar
rodnok
Default changing fuel filter 98 24 valve.
I read the sticky for changing fuel filter, but the pictures are gone. It says to use a large crescent wrench or a 1 1/8 socket. There is no place to use anything that large on my filter housing there is a nut on the top of the filter that looks to be about 5/8. Is this the bolt I need to loosen? It would be the bolt in the center of the top.
Old Nov 14, 2012 | 11:40 AM
Jigabop's Avatar
Jigabop
loosen that. top cap should come off.
Old Nov 14, 2012 | 10:03 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
I'm guessing the sticky is for the common rail engines. The fuel filter is different than what you have. I believe your filter unscrews from the holder you are showing in your picture. IIRC yours gets changed just like an oil filter.
Old Nov 15, 2012 | 11:27 AM
Jigabop's Avatar
Jigabop
newer vp44 trucks have a different filter housing as well...like my 2000 for example...stock housing has a big plastic top that the whole top unscrews and it has a large nut/bolt shape in the middle to put a large wrench on to unscrew the cap.
I have that filter bypassed though as I have an airdog system now.
Old Nov 16, 2012 | 10:39 PM
ytlogger's Avatar
ytlogger
I have that type. You loosen that nut in the center and the bottom section is the canister that drops down. Drain the fuel with the yellow lever and catch below. Make sure that you have the right filter element. It took me two tries to get the right one. If you have your owners manual it should give the MOPAR number that you can cross reference. Fill the canister and filter with clean fuel before you start to put it back on or you will be bleeding forever.
Old Dec 1, 2012 | 04:09 PM
rodnok's Avatar
rodnok
got filter changed sucessfully
Old Dec 3, 2012 | 05:49 PM
iwhitne's Avatar
iwhitne
while you have it off... fill the fuel filter cup with straight power service before install... start truck and let run 5-10 sec then shut off.. let it sit for 24 hours then start her up...this will help burn any stuff off your injectors
