Cooling fan replacement
Old Dec 26, 2012 | 05:20 PM
bouncdchk's Avatar
bouncdchk
Default Cooling fan replacement
So a blade broke off of my cooling fan the other day and destroyed my radiator. Sucks but I have a new radiator.
And none of the local auto parts stores have a new fan available. Through searches is seems as though I may be able to use a fan off of the Durango.
Anyone have any experience with this issue? And where I might be able to find a new one (besides a dealer).. I really don't want to hit the junk yard cause I don't want the same thing to happen ago. Radiator already cost me $200.
It's a 1999 Dodge Ram 2500 Turbo Diesel
Thanks in advance!
Old May 15, 2018 | 02:32 PM
Eazzy's Avatar
Eazzy
Close to same trouble. Good luck. Did you get a fix? Why haven't you got a reply?
I just posted... 2006 Ram Mega cab 2500, 5.7 diesel, mileage now 196,742, fire red. I hit hole of water & broke radiator fan blade & wiring pulled away from a/c clutch. I tried a patch job. Good cool air while driving but when idles a/c puts out hot air. I want to change electric a/c fan clutch to thermal. I have changed elec a/c fan clutch 3 times, appears to be a bad design as my son has trouble also. He has 2004 Dodge 3500 diesel. Since I have to change radiator blade I thought a good time to change all. What blade is compatible to a thermal fan clutch? What kind of adapters do I need? Wiring changes?
