Having Issues..
Old Jan 30, 2013 | 12:16 PM
AlaskanRenegade's Avatar
AlaskanRenegade
Default Having Issues..
I've got a 98.5 Cummins 24v, I've posted all over and have hardly made any progress..
I'll make it short.
Cold day, colder then -15*F, plugged in for 2 hours, tried startin after cycling the intake grid 3 times, wanted to fire but it wouldn't. Cycled 3 more times, almost fired, then I smelled smoke, starter was dumping smoke.
Replaced the starter and starter relay, won't turn over. jumped the starter, it's got power.
Noticed my WTS light wasn't coming on so I replaced my intake manifold heater relay unit. light comes on now, still nothing.
I got a code reader and i got these codes,
P0234- Turbo over boost
P1693- Companion DTC set in both PCM and ECM
P1689- No communication between ECM and Injector Pump Moduel..
the code list on this forum says different.
P0234- Engine over boost
P1689- Oil Pressure Control Solenoid Circuit Malfunction
P1693- Turbo Charge Control Circuit Malfunction
I'm pretty much at a loss and fed up with this thing!
Old Jan 30, 2013 | 01:28 PM
Jigabop's Avatar
Jigabop
is your fuel gelled?
pull the fuel filter and check it.
and what is your fuel pressure?
Old Jan 30, 2013 | 08:47 PM
hillbilli's Avatar
hillbilli
check all your battery connections also.
