03 3500 White smoke
Old Aug 27, 2013 | 04:19 PM
weffer69's Avatar
weffer69
Default 03 3500 White smoke
I have a 2003 dodge 3500 4x4 dually (5.9)
Problem: White smoke out the tail pipe often(so im told) I was told by multiple people that i was blowing white smoke on the way out of work yesterday, i cannot see it all i see if black since the tuner is set on 5, i sometimes see the occasional gray but they told me it is every time i hit the gas. I do put mystery marvel oil in it and i know that could cause white smoke but im also low on coolant. I did get a new water pump and they might not have filled it up all the way. What do you think is wrong with it? if there is how do i check?
Things on the truck: smarty s06 tuner, straight pipe, 6 inch lift(nothing to do with the issue)
Old Aug 27, 2013 | 06:26 PM
scatpack_69's Avatar
scatpack_69
If you're blowing white smoke, it's probably going to be injector related.
Does it run rough ever, or hard to start at all? Ever?
Old Aug 27, 2013 | 08:48 PM
weffer69's Avatar
weffer69
never idles hard, hard to start if i dont wait for the glowplugs to heat up
