Fuel pump not priming up 2003 ram 5.9 diesel
Old Oct 18, 2013 | 12:51 AM
penelopesdaddy's Avatar
penelopesdaddy
Default Fuel pump not priming up 2003 ram 5.9 diesel
Hi I have 2003 2500 ram in the uk it's a 5.9 diesel , I have had it parked for about a year I came to start it and noticed the fuel gauge was not registering although I put fuel in it also the fuel pump is not running to prime it up , I can't find a fUse or relay to check can you help with getting it up and running , as far as I can tell all other systems are working fine .
Thanks in advance
Old Oct 18, 2013 | 12:17 PM
Jigabop's Avatar
Jigabop
do you have the block mounted lift pump, or the in-tank lift pump?
Old Oct 18, 2013 | 01:25 PM
penelopesdaddy
Hi it's a block mounted on the side of the fuel filter housing , is there a fuse or relay I don't see any on the PCM
Old Oct 20, 2013 | 04:03 PM
Jigabop's Avatar
Jigabop
there should be a fuel system relay, and one or two fuel system fuses.
