engine swap: 2nd gen to 3rd gen, cummins
Old Jan 26, 2014 | 12:18 PM
tsviker's Avatar
tsviker
Default engine swap: 2nd gen to 3rd gen, cummins
My truck 1999 2500 cummins body has turned to rust. Where I live you cant find rust free gas 2500s so I was thinking of swapping my cummins in to a 3rd gen gas 1500 or 2500. Is my running gear on my truck compatible to the 3rd gen if I swapped the axles w/brakes to a 1500 including the cummins? I've done other swaps, just looking for easiest swap w/o buying newer cummins.
Old Jan 28, 2014 | 12:00 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. Moving you to the correct spot.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Jan 28, 2014 | 12:30 PM
Jigabop's Avatar
Jigabop
getting ECM and PCM to work with the instrument panel on the 3rd gen would be a chore. and the cruise control wont work anymore as pre-01 used vacuum control for cruise, and 01 + used electronic cruise control.
vent control may or may not be an issue.
not sure if they still used vacuum to control the vent blend door still
