05' 2500 Cummins A/C Probs...
We have had out 05 3/4 ton dodge ram cummins turbo diesel 7 years give or take
For a while the A/C had been leaking freon we finally got it fixed (gasket)
and then when vacuuming out the system we didnt get a tight enough vacuum so you could put all the freon in you wanted but it would only last a day or 2 So we put in a new condensor today and made sure we got that thing sucked down tight.
But when we were putting freon back in this time the A/c line going into the cabin is freezing and icing over on the outside and the line wont defrost until we completely shut off the engine
Any comments are helpful
No no we would put freon in and it would freeze before we could get more than 1 whole 12 oz can
Yes we hooked it up to gauges and all that
So today we took it to an auto shop
They hooked it up to their computer and all their ****
then they said bring it back tomorrow we'll do so and so and so
450 bucks BS!!!!!!
We are on our way home we turn on the A/C and its blowing 41 degrees!
I think it was an airflow block they knocked loose in the radiator or somewhere
450 bucks BS!!!!!!
