Cruise control not working
Old Jul 5, 2014 | 11:07 PM
Lineman12's Avatar
Lineman12
Default Cruise control not working
I need some help!! I have a 98 12 v dodge diesel and my cruise control went out a few weeks ago. I have done some research on what to look for.. I have check the vacuum line for the servo and it was good, I replace the switch where the brake pedal is. The cruise control light comes on but it won't set or anything. So what do I do ? Start replacing parts until I fix it or if someone has had the same problem that could to relate to this that would be helpful. Thanks kirk
Old Jul 6, 2014 | 08:22 PM
p38251's Avatar
p38251
Gas truck gets its signal from the LF wheel bearing sensor. Not sure if diesels are the same.
Old Jul 7, 2014 | 02:06 AM
horatio102's Avatar
horatio102
Any other issues? Tach work? ABS/Brake lights on? Check for codes?
