Need help!
Old Jul 21, 2014 | 07:57 PM
cowboy1951's Avatar
cowboy1951
Default Need help!
I have a 2007 Dodge Ram 2500 with 5.9 Turbo Diesel Engine. My problem is that I have several diagnostic codes appear (posted on other thread). As I was checking out the engine, I noticed that there is a partial wire harness that runs from the bottom of the engine upwards in between the power steering pump and the fan that looks as if it has hit the fan and was chopped off. It looks as if there were between 2 and 5 wires in the harness but I can't find where the other ends should be. It is in what appears to be a metal bracket up to where it was mysteriously destroyed. Is there anyone that maybe knows where these wires are supposed to go or help me in some way. I sure would appreciate it. Thank you.
charles
Turns out it is the cooling fan clutch electrical connector that is missing a considerable length. Now all I have to do is replace the cooling fan clutch...
