5.9 Diesel Transmission issue
Old Oct 14, 2014 | 09:13 PM
5.9dieseltrans's Avatar
5.9dieseltrans
Default 5.9 Diesel Transmission issue
I have a 2006 Dodge Ram 2500 5.9 (AT) Diesel. At this time I am having an issue with the Transmission not shifting. Also the Dash indicator, Govenor Solenoid and OD/Tow-Haul indicator do not have power. I have sent my ECM/PCM out for testing to ensure it works and it came back fine. I can shift on the column like a three speed.
If anyone knows where I should start please let me know? Any help will be appreciated!
Old Oct 16, 2014 | 11:16 PM
horatio102's Avatar
horatio102
Have you checked all of your fuses?
You sent the computer out that is bolted to the firewall on the passenger side, right? Not the one bolted to the side of the motor.
I suppose it could be a TIPM problem too.
How did you determine the gov pressure solenoid doesn't have power?
Old Oct 17, 2014 | 11:29 PM
5.9dieseltrans
Checked all fuses. Had the truck at the tranny shop and at dodge. Guy at dodge thought the computer was bad. The trans shop looked at it said he thinks the trans is fine but there was no power goin back. He thinks I have a broken wire or some type of electrical problem. Just don't no where to start
Old Oct 17, 2014 | 11:32 PM
5.9dieseltrans
What computer on the passenger side are you talking about. I only have the one on the block
Old Oct 22, 2014 | 10:25 PM
horatio102's Avatar
horatio102
You don't have a computer on the passenger's side of the firewall? White looking box in this picture next to the receiver dryer, top left?
http://i272.photobucket.com/albums/j...6/100_1627.jpg
Granted that's a 12-valve, but my 08 6.7 had a TCM up in that same spot too. Maybe 06/07 are different.
Old Oct 23, 2014 | 10:13 PM
5.9dieseltrans
No just the dryer and coolant reservoir
Old Oct 25, 2014 | 12:11 AM
horatio102's Avatar
horatio102
Too funny. Older ones and newer ones have computers up on the firewall for the transmission.
