Transmission overhaul
Old May 7, 2015 | 09:32 AM
HSTEX's Avatar
HSTEX
Default Transmission overhaul
What cost should it be to get a 2007 3500 Dodge cummins diesel transmission COMPLETLY overhauled including coolers. It is a four wheel drive automatic transmission. Thanks!
Old May 7, 2015 | 08:06 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
With stock transmission or upgraded?
My transmission was rebuilt about 3 years ago and I put in $3500 in just parts. I did the work myself. Many internal parts were upgraded. I know you can get a stock transmission rebuilt for around 3k plus labor to remove and reinstall.
I just put in new coolers (both the one in front and the one on the side of the engine) and lines a couple of months ago. That bill was about $900 in just parts.
Old May 8, 2015 | 02:59 AM
horatio102's Avatar
horatio102
Depends on what you want done. I put about a thousand bucks into mine, just went with upgraded clutches and the upgraded transducer. I'm pretty sure the check ball in my cooler line plugged up and took out my OD clutches. I had previously put about a thousand into a billet converter and upgraded clutches in the rest of the trans, plus shift kit and billet accumulator piston.
