What air filter kit cold air intake is best?
Old Nov 8, 2005 | 07:57 PM
pluguglyinhere's Avatar
pluguglyinhere
Default What air filter kit cold air intake is best?
So I am going to start my mods off slow and hopefully not effect my warranty. So which ari box do you all recommend? K and N or ARE or what? Also I heard somehwere that this may raise my EGT's true? or nothing to worry about?
Old Nov 8, 2005 | 08:12 PM
bigmike's Avatar
bigmike
Default RE: What air filter kit cold air intake is best?
i have an Airraid Intake on my 04.5. i like it and it was easy to install. i doubt if any brand of intake is that much better than the others, but some of the other guys may know more about this.
Old Nov 8, 2005 | 10:43 PM
Irish4u1978's Avatar
Irish4u1978
I went withan afe stage 2 with pro guard 7. I think filtration is important, so I went with the pro guard 7. I think it has better filtration than most. I think a stage one is good, and the stage 2 is good, or for like $90 you just drop a filter in your existing box.
Old Nov 8, 2005 | 11:21 PM
pluguglyinhere
Whats the difference between stage 1 and 2?
Old Nov 9, 2005 | 11:18 AM
Drew's Avatar
Drew
one word. . .
BHAF
any of the filters below will work
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
AFE 20-40044
Carquest 87790
John Deere pmah19037
Big A 93790
Caterpillar 3i0005
Fleetrite ahr819037
Luber-finer laf2531
Fram ca6818
UNI 908
Old Nov 9, 2005 | 12:21 PM
88406vette's Avatar
88406vette
I wouldn't reccomend the K&N cold air kit alot of people are having probs with the plastic cracking
Old Nov 10, 2005 | 03:56 PM
donnie's Avatar
donnie
Personally, I installed the Airraid Jr on my 05.
I ordered it with the MIT and did notice a little better throttle responce.
Old Nov 10, 2005 | 04:47 PM
Daytona RT's Avatar
Daytona RT
Without knowing precisely which model your modifying I'm not sure how much room you have or what would work best for your unit. I have had some great luck with the series 63 K&N. Doing my research with some performing gearheads, I got almost unanimous endorcement of K&N units. Most have the fitting to reinstall your air flow sensor. I would insure compatability before buying, but If you match the intake to your unit, chances are good you'r not likely to have any sensor conflict.
Good Luck
