1999 Dodge Ram 3500 Diesel - Electrical Issues - Lights
Old Apr 1, 2016 | 01:33 PM
TigaHotty85's Avatar
TigaHotty85
Default 1999 Dodge Ram 3500 Diesel - Electrical Issues - Lights
Hi, the issue we are having is with the driver side. The turn signal goes super fast. Checked & replaced all bulbs that they are all brand new. Still blinks fast...
Then the kicker is the front running light on driver side won't work with it just on. But blinks when the turn signal is on. Everything else on that side the bulbs work fine...
Any advice would be appreciated.
Ps, have checked ground wires and made sure were clean or cleaned them. Still does not work or fix the problem.
Old Sep 13, 2016 | 03:10 PM
Steven Lynch's Avatar
Steven Lynch
Default Going nuts with Lights
I have a 1999 dodge 3500 ram and the stop light, turn singles,4 ways have stop working tested all fuses, replace relay, flasher, turn switch, bulbs and they still will not work getting power to flasher. Can some one help
Old Sep 14, 2016 | 04:20 PM
p38251's Avatar
p38251
I believe that has a double element bulb? Sounds like you only getting power to one side. Possible bad wire or socket.
Old Sep 15, 2016 | 01:30 AM
horatio102's Avatar
horatio102
Steven - have you pulled your headlight switch to check for melting?
