What is your cold oil and coolant temp ?
Old Feb 6, 2019 | 10:05 AM
scoff's Avatar
scoff
Default What is your cold oil and coolant temp ?
I have a 2015 eco diesel. I’ve been looking at my fluid templatures lately being the wintertime and noticed when my truck is off and it’s like -10 degrees C outside my oil and coolant show 40 degrees C, every morning both the same. Everything else show normal below zero temps.
I thought my sensors were out but when I drive it they do increment and do so independently.
A guy at work who was having block heater troubles has he same truck and his oil and coolant show below zero. His is a 2018 model.
He said something must be wrong with my sensors.
I took it in and they confirmed with trucks on the lot they all say 40 degrees C when off.
What are yours?
Old Feb 6, 2019 | 10:12 AM
Probably 40 is the minimum it will show, like it's the bottom of the temperature scale used.
Old Feb 6, 2019 | 04:26 PM
scoff's Avatar
scoff
Can someone check before the next time they start their car and confirm what your temperatures are to be sure?
