2001 Dodge Ram 3500 4x4 grinding/vibration at 70
Old Mar 22, 2021 | 11:03 AM
Troy Gipson's Avatar
Troy Gipson
Default 2001 Dodge Ram 3500 4x4 grinding/vibration at 70
2001 Dodge Ram 3500 vibration in the floor board sounds like it is coming from the front driver side but noise travels a lot. New wheel bearings transmission, transfer case, carrier bearing. Ujoints Pulled driver side axle and drove it same issue pulled front drive shaft same noise only at 70 if you drive it at 60 and the noise is not there don’t matter if u turn right or left noise stays the same. Any ideas would help. I am lost
