maby u can help me out Drew
Old Mar 9, 2006 | 04:24 PM
hummincummins's Avatar
hummincummins
Default maby u can help me out Drew
can i put 24 valve injectors in a 12 valve head??
Old Mar 9, 2006 | 04:34 PM
Drew's Avatar
Drew
Default RE: maby u can help me out Drew
I'm pretty sure you can. but you cannot swap HPCR injectors.
Old Mar 10, 2006 | 01:29 AM
hummincummins
what are hpcr injectors
Old Mar 10, 2006 | 10:15 AM
Batphreak's Avatar
Batphreak
High Pressure Common Rail (HPCR)
That's on the '03+ engines.
Old Mar 10, 2006 | 11:32 AM
Drew's Avatar
Drew
02 and earlier injectors are 'jerk' style. they fire from the pressure generated bu the pump. normaly around 5-6000 PSI
the HPCR injectors are electronicaly fired like solenoids. the pressure in the rail can sometimes be as high as 20-24,000 PSI. 3-4X the pressure of the previous models
