2006 silencer ring
Old Mar 23, 2006 | 01:27 PM
steve05ram360's Avatar
steve05ram360
Default RE: 2006 silencer ring
ORIGINAL: heresdamanladies
so did the stage 2 kit make a big difference ? thx
yeah, did it? inquiring minds want to know...
Old Mar 23, 2006 | 03:00 PM
06LiftedRam's Avatar
06LiftedRam
Yes that air intake kit is HUGE and really allowed the turbo to sing!!! Very easy to put together with good instruction. Should only take 40 minutes at most with no help or special tools. One work of advice the next to last step is the hardest which instructs you to put the entire system into place. Making the connection at the turbo was difficult due to the shear size and limited space you have to work with. Make sure your pre installed clamps are as loose as possible. I would recommend the system to anyone who has or is doing performance upgrades or if you truly want your truck to sound like a jet taking off remove the silencer ring prior to installation of the cold air kit.
Old Mar 24, 2006 | 07:09 AM
heresdamanladies's Avatar
heresdamanladies
cool thanks im looking to get a intake kit i might pick up that one
Old Mar 24, 2006 | 10:08 AM
Drew's Avatar
Drew
I know the pic is dark, but this is my red neck BHAF
$45 spent at napa, 1/2 inch drill bit to re-locate the AIT and a long flat head screwdriver to pry the thing on. this thing should last me 10x as long as the stock air filter
Old Mar 25, 2006 | 07:21 AM
heresdamanladies
haha thats awesome
Old Mar 25, 2006 | 07:24 AM
heresdamanladies
so for my 06 i have to take that baffle out and take the ring out to which is in the turbo ill see it when i take the hose off to mess with the baffle right ? thanks sorry hofully ill get this done soon so i can quit bugging you guys about it lol
Old Mar 25, 2006 | 02:04 PM
brampage's Avatar
brampage
have you listened to it when someone elsi is driving it when your not in it? Thats when younotice the jet within
Old Mar 25, 2006 | 08:53 PM
06LiftedRam
Check out this link below. It should help with the silencer ring. As for the baffle in the intake hose, I can't help other than say throw it out and get the AFE stage II. I also understand the money issue so best of luck to whichever route you take.
http://dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
Old Mar 27, 2006 | 10:08 AM
Drew's Avatar
Drew
you'll see the baffel in the hard plastic part
Old Mar 28, 2006 | 08:15 AM
heresdamanladies
cool thanks alot
