Edge juice w/attitude for 98.5-02
Old Mar 20, 2006 | 03:19 AM
Irish4u1978's Avatar
Irish4u1978
Default Edge juice w/attitude for 98.5-02
Have you guys seen this CLICK HERE Looks like it has more features than the one on my 05. Built in turbo timer, fuel pressure, trans temp. It isn`t listed on the edge site however. I want all those features on mine[:@]
Old Mar 20, 2006 | 02:57 PM
steve05ram360's Avatar
steve05ram360
Default RE: Edge juice w/attitude for 98.5-02
hell yeah the turbo timer would be nice! Some alarm systems also have that feature as well as the delayed remote start.
on a different subject... how do you like your afe stage2 setup? what benifits did you see after the install? does it help spool the turbo up faster?
Old Mar 20, 2006 | 03:58 PM
Irish4u1978
I like the afe setup. It was a bit expensive, but I only wanted to do it once. I went with the proguard 7 filter because I don`t want to sacrifice filtration. It took a little getting used to hearing the turbo. It is loud, but I like it now. I`m not sure if the intake alone helps the turbo spool any faster, but with the juice it spools up pretty fast. I added the juice and intake on the same day at about 5k miles, and now I am at 25k miles. The only thing I would change is adding the prefilter when I installed the intake instead of buying the prefilter later.
Old Mar 20, 2006 | 04:23 PM
steve05ram360
what is your exhaust setup like? did you get the "torque tube" with your AFE kit?
Old Mar 20, 2006 | 10:19 PM
Irish4u1978
Its a stage 2 kit, so its everything up to the turbo. My exhaust is still factory 4".
