Rear end or tranny
Old Apr 3, 2006 | 01:57 PM
BFR's Avatar
BFR
Default Rear end or tranny
ok so here is the sittuation. i have a 1998.5 2500 club cab long box ctd. and if i drive it for a long period of time at high speeds (long enough for everthing to get to opp. temp) i develope a slip or shudder somewhere when im turning. almost seems like the trans is slipping but it only does it at slow speeds when im turning or braking. not in a straight line. it has a limited slip rear end and i belive thats what it is but i have never felt one do this. im wanting to know if ne one else has experianced this or what else could be causing this. i just bought the truck and i dont know if maybe the guy b4 me didnt put the right additives in the rear end or what.
Old Apr 3, 2006 | 04:29 PM
Batphreak's Avatar
Batphreak
Default RE: Rear end or tranny
Sounds like what happens when the friction modifier isn't in the rear-end. Good place to start by throwing a bottle in there.
Old Apr 3, 2006 | 05:07 PM
BFR's Avatar
BFR
is there a spicific kind or nething like that also will there be ne long term dammage if there isnt
Old Apr 3, 2006 | 05:16 PM
Batphreak's Avatar
Batphreak
I'd just get a bottle form the dealer, I think it's about $10. Without it you will eventually blow the LS clutches out, not a real big deal, they usually just fall to the bottom of the housing and sit on the magnet, but you then have a one wheel wonder instead of LS rearend.
Old Apr 4, 2006 | 12:59 AM
BFR's Avatar
BFR
ok thanx
