Need turbo for an 01
Old May 9, 2006 | 11:46 PM
Irish4u1978's Avatar
Irish4u1978
Default Need turbo for an 01
Hey guys. My brothers truck needs a turbo, its an 01. Want something better than stock, but is a direct bolt up. The truck is just about stock. It only gets better parts when the originals fail. It has an ATS transmission, and a fass pump. Other than that its stock. Thanks. Kevin.
Old May 10, 2006 | 01:57 PM
steve05ram360's Avatar
steve05ram360
Default RE: Need turbo for an 01
go here... they have turbo upgrades.
http://www.bd-power.com/
Old May 10, 2006 | 10:38 PM
CUMMINS MAN's Avatar
CUMMINS MAN
I Have A Edge Jammer Turbo On My 01 CTD With The Edge Hot Box And Stage 3 Edge jammer injector's And Love The Turbo
Old May 11, 2006 | 01:12 AM
Irish4u1978
It has to be a direct bolt up to the factory intake, and exhaust.
Old May 11, 2006 | 12:43 PM
Drew's Avatar
Drew
phat shaft 66, or the 66/14 are direct bolt on.
the edge jammer should be bolt on as well.
most places you hit up on the internet will ensure the turbo will bolt to the exhaust manifold
Old May 11, 2006 | 10:29 PM
CUMMINS MAN
The Edge Turbo Is A Direct Bolt On.
Old May 15, 2006 | 10:24 PM
Irish4u1978
Thanks for your replys. I been doing research, and what do you guys think of this set up for the 01. HTBG turbo from HTT, Afe stage 2 intake, 4 inch turbo back exhaust, and edge juice with attitude. I was thinking about the Hx35 turbo as well, because the guy at htt said the larger turbo will have more lag, and will smoke more under light load until it is spooled up. So, will the truck run ok if the edge is set at stock setting? What do guys think?
