Turbo issues? Help
Old May 22, 2006 | 04:10 PM
farfree2's Avatar
farfree2
Default RE: Turbo issues? Help
THANKS!!! a million for all your help peoples. I really do appreciate it. You all are great!!!
Ok, going to pick up part now.
Is the MAP sensor accessible from the Hood or underneith?
I know you said it was on drivers side towards back of block, is it above or below starter?
Old May 22, 2006 | 06:28 PM
farfree2's Avatar
farfree2
DID I TELL YOU GUYS I LOVE YOU!!!
This is the best forum ever!!!!!!
Ok, here is the update:
Picked up new map sensor.
Found where it goes and installed it.
Mine is a bit harder to get to no thanks to the prime-loc remote fuel management system that I have in mine (what is the point of that anyway????)
Had to move the big a#$ filter and chrome plate out of the way so that I could get a socket and my hand down in there to swap it out.
On the upside its all done, now the big question is, will the check engine light go off and the CPU correct itself??????
Guess I will find out on the ride home today (I hope)
Just wanted to say thanks so much everyone (kossuth, Drew, tcarothers, steve00ram360, tobinj) for your comments and for all your help.
You all rock!!!
I'll let you know what happens after the ride home
Thanks Everyone Again!!!!!
Old May 22, 2006 | 06:44 PM
steve05ram360's Avatar
steve05ram360
glad to hear it's fixed, how long did it take you to do the swap?
Old May 23, 2006 | 01:32 AM
tcarothers's Avatar
tcarothers
Took me longer to find the dang thing than to swap it out, all total, about 15 minutes. ( I didn't have to move any aftermarket parts on mine
Old May 23, 2006 | 11:30 AM
Drew's Avatar
Drew
the CEL should go out after about 5 starts.
enjoy the ride!!!
Old May 23, 2006 | 10:09 PM
farfree2's Avatar
farfree2
Just an update for you all.
It has now been a full 24 hours of a lot of driving. So far so good. The SES light went out on my way home last night, and hasn't been back since.
All is running great.
Yes, it took a whopping 15 min to switch out. Just was still a little hot because I drove it to get the part.
Everything works great.
Thanks again to you all, I really appreciate the help!!!!!!!!!!!!!!!!!
Old May 24, 2006 | 10:14 AM
Drew's Avatar
Drew
now the true test will be to see how you fuel mileage has increased
Old May 24, 2006 | 06:32 PM
farfree2's Avatar
farfree2
went from 14 to 16.5 mpg so far...........just topped it off today(have a 100 gal aux tank in the bed) we will see what happens.
I know I should probably start a new thread on this question but wtf, I'll ask here for the heck of it.
Whats the best programmer you all would add to your big D? EZ, 6 gun? Which would give me the biggest bang for the buck?
Old May 24, 2006 | 07:11 PM
Drew's Avatar
Drew
for a 99 ram the pickings are going to be slim since the the only electronicaly controlled part of the engine is fuel pressure via the MAP sensor. the injectors and timeing are still mechanical, I believe.
