CEL codes, what do they mean?
Old Nov 2, 2006 | 04:32 PM
Drew's Avatar
Drew
Default RE: CEL codes, what do they mean?
they even read the hour meter and divide that into the miles and can tell on average how fast you have been going, the computer also logs how many hours below 1200rpm which is considered idleing to DC. if you have an injector go bad and alot of idle hours they will point the finger at you for the bill.
Old Nov 2, 2006 | 05:20 PM
Mayfair's Avatar
Mayfair
ORIGINAL: dodgedlr
Not sure why this bothers me so much, but I just have to vent....
The proper term is MIL.
Malfunction Indicator Lamp.
I know everybody in the world calls it a Check Engine Light.
But I just had to vent.
[sm=sigh.gif]
You remind me of this guy I used to know. He used to go OFF whenever someone would ask what size motor he had in his car. He'd FREAK because a motor is an electrical term and he has an ENGINE under his hood and blah blah blah .....
I believe he eventually comitted suicide ....
Old Feb 18, 2007 | 02:19 PM
cardude's Avatar
cardude
that’s super nice, thanks for the link, I got a p 0341 and p 0340 error code when doing 3 cycles on the ignition.
Camshaft Position Sensor Circuit Malfunction
and
Camshaft Position Sensor Circuit Range/Performance
all due to a very small amount of grease/dirt on the pulley/timing-taps, very easy to fix and its all running fine now
the engine sometimes stopped running for just 1/10 of a second around 2300 rpm's but i gave a hek of a jolt in the car when it did. Also the idle got a little fluctuating.
Thank you very much.
But how do you get the MIL light to stop glowing besides taking the bulb out of course. I have tried on/off 5 times, and actually more
Old Feb 21, 2007 | 12:05 PM
cardude's Avatar
cardude
ORIGINAL: cardude
and
Well someone must have been laughing there *** of when I wrote this, the sensor i was cleaning was the crankshaft sensor.
Now I am trying to find the camshaft sensor, does anyone have a picture or a description of this sensor and where it is located? plz help a fellow dodge driver on the other side of the Atlantic without warranty.
the cars is dodge ram 2500 hd 4x4 with cummings diesel.
Old Feb 21, 2007 | 01:27 PM
Drew's Avatar
Drew
if it is an 03 or better the cam sensor will be located just above the crank sensor. it will be kinda hard to see but it is stuffed right next to the ECM. the Cam and Crank sensors are the same, the wireing harness to the and the connectors are the same.
Old Feb 21, 2007 | 08:29 PM
cardude's Avatar
cardude
it is a 2005, so i wil try to find it tomorow, maby a mirror wil help a bit.
but the engine only goes in "failsafe" mode for like ½ a second under heavy acceleration or acceleration after just driving the same speed for long time.
i do suspect a wire failure, with these symptoms
update will folow.
here in denmark we now have a snowstorm, heavy snow and strong wind. somthing to play in with 315/70-r17 all teraion BFG
Old Jun 8, 2007 | 07:33 PM
cardude's Avatar
cardude
just as an update, it was the camshaft sensor that was bad, the dealer here in Denmark said that it was the same as a other car that they knew was prone to fail from time to time. change took 2 hours, and i had to remove the computer from the side of the block to be able to get to the sensor.
but it worked.
Old Jun 9, 2007 | 12:28 AM
dieselram's Avatar
dieselram
ORIGINAL: Drew
Wow, thats quite a contrast to when I pushed my fan clutch wiring through my fan in a creek. They said its "actually quite common" and replaced it under warranty.
[Edit: I never go off-roading and do not modify my vehicle in anyway. Any vehicle problems are not my fault and therefore covered under warranty. This comment above is purely hypothetical and intended as a "what-if" scenario]
Old Jun 9, 2007 | 11:42 AM
FroneDaddy's Avatar
FroneDaddy
Sounds like a challenge Drew....
