o6 trans questions
Old Aug 3, 2006 | 03:17 AM
i11m10c2's Avatar
i11m10c2
Default o6 trans questions
ok had the truck for 3 days and the auto tranny is acting weird shifting all the time ( in town driving) very eratic when i let up then put the throttle back on then it changes 2-3 times before i figures it out ,and all gears shifting real hard??
is this because it is learning or because im babying it for the first 500 miles slow accel(not reving above 2000) or is the trans screwed up
the truck i traded was 5spdauto hemi pretty smooth compared to thisand it only acted wird for 50 miles, i now have 130mi on the diesel
thanks
Old Aug 3, 2006 | 10:21 AM
Drew's Avatar
Drew
Default RE: o6 trans questions
this might be something to look into. . .
TSB 18-003-06
Models: 2006 DH/D1 Ram Truck Heavy Duty
NOTE: This bulletin applies to Ram trucks equipped with the 5.9L Cummins 24-valve
diesel engine (sales code ETH) built on or after June 9, 2005 through and
including November 8, 2005 (MDH 0609XX and 1108XX).
Overview:
This bulletin involves Flash reprogramming the PCM (Cummins) with new software.
Symptom/Condition:
The vehicle operator may experience extended engine crank time in cold ambient
temperatures on vehicle equipped with manual transmissions.
This Flash also provides the following enhancements:
Improved Automatic Transmission shifting
Engine fan is activated if the coolant temperature sensor fails
Enhanced battery charging
