ECM update for better Mileage?
Old Aug 3, 2006 | 07:26 PM
ben362's Avatar
ben362
Default ECM update for better Mileage?
I searched here to see if this has been talked about. I heard from a friend that there is an update for the ECM mapping that gives 1-2mpg's.
Anyone know of this?
Thanks,
Ben
Old Aug 3, 2006 | 07:32 PM
Drew's Avatar
Drew
Default RE: ECM update for better Mileage?
that depends on what year truck you have. if your overhead is WAY out, you have white smoke at start-up, or flat spots in engine performance then the flash is out there and it does give a little better mileage.
#2, do a google search on the Rokk Tek crank sensor. this little guy will advance the timeing of the injectors by about 2* giving you a little better bottom end, slightly better fuel mileage, and a cooler running engine.
hope this helps.
Old Aug 3, 2006 | 07:39 PM
GOD RAM IT's Avatar
GOD RAM IT
how much do they cost and how involved is the installed?
Old Aug 3, 2006 | 08:03 PM
Drew's Avatar
Drew
they are $70 bucks and take about 2-5 min to install
check it here
not be warned though, if you add a performance box that adds timeing you will get poor performance from too much timeing
Old Aug 4, 2006 | 02:55 PM
ben362's Avatar
ben362
Mine is an 05 QC 4x4 3500 19.8k miles the best I have seen unloaded is just over 16mpg hand calculated.
Old Aug 5, 2006 | 05:14 PM
jagj52's Avatar
jagj52
Hey Drew...
I just got and installed a Banks Boss Hoss tuner for $250.00. This helped with the performance but not really sure about the MPG yet. Will this unit you are talking about work with the tuner or will it be a waste of money and time to get?
Old Aug 5, 2006 | 05:15 PM
jagj52's Avatar
jagj52
Hey Drew...
