Edge Juice with Attitude Hot Unlock????
Old Aug 21, 2006 | 04:09 AM
rfinn04's Avatar
rfinn04
Default Edge Juice with Attitude Hot Unlock????
Hello, I am a New Diesel owner 06 cc, sb, 4x4, 6 spd, 3.73. I have already dropped in a replacement K&N, Aero turbine xl, and an edge juice with attitude. My question is, has anyone tried the hot unlock code yet or even heard how the 160 horse setting runs. I am very mixed on if it is worth the $100 to purchase it I do not drive the truck very often on setting 5 as it is but would like a little more performance out of it. Any comments would be great.
Old Aug 21, 2006 | 01:15 PM
steve05ram360's Avatar
steve05ram360
Default RE: Edge Juice with Attitude Hot Unlock????
welcome to DF...
I have the juice w/attitude and havent considered the upgrade, my torque converter and tranny cant handle much more than the 60~70 hp I get out of the edge before they start slipping. those 2 items need to be swapped out to be able to use the updated programs on a regular basis. i'd assume your tranny would have an issue at some point. there are upgraded clutch packages that you can get to hold the power better.
Old Aug 22, 2006 | 02:12 AM
sharx ram's Avatar
sharx ram
I talked with my mechanic about upgrading mine, he say's that Iam walking a fine line with the trans as it is, any more power would do it in alot quicker he said, he says its a great deal for more power but I need to beef up the trans alot first...I know...it's not the answer I wanted either![8D]
Old Aug 22, 2006 | 02:47 AM
rfinn04's Avatar
rfinn04
Even the manual will not hold up better then the auto? What kind of upgrades are we talking for the manual? Also has anyone heard of a short throw shifter for the G56 yet?
Old Aug 22, 2006 | 11:15 AM
Drew's Avatar
Drew
when I put my TST to the +75hp(3) +120tq(2) setting my stock clutch begins to have a problem holding, but only in the upper RPM's. Ive done some playing around with the higher HOLY CRAP settings of 5 and above and just a blip of the throttle and the clutch no longer holds. if you need a better clutch check out South Bend Clutches
now why do I say this in this thread, as soon as you start putting down big numbers, the stock clutch just aint gunna hold.
my box does 35horse on setting 1 and 20 more 2-9, and will increase torque 60ft-lb starting at 1-9, so you can see how much power this bad boy can produce
