TST MPG review (-> Drew hint hint)...
has anyone tested their tst for mileage improvements (read Drew have you tested...) lol
The tst will be my next box... this whole edge thing sucks as I was looking to do a VB upgrade [:@]
So far from the mileage I have on the tank and the possition of the fuel needle it does look like something is there. it takes me nearly two weeks to burn through a tank though
but just remember last tank I got 16.6 and this was flogging it with the TST turned up most of the time
yes my clutch hated me[8D]
Check out this TST
it has the economy setting, Standard setting(what I have), 03-04 'Early Twins' programming where full fueling is at 12psi to get twins or those big singles spun up, 04.5-06 twins which does the same but doesnt fuel untill 24psi, 18 degrees of adjustable timeing, auto cool down, and can do pressure fueling as well.
just to give you a heads up on the early or late twins programming, both will work with any year truck, but the early twins fuels quicker and is WAY smokier then the late twins. the early twins is normaly what is used by dragsters and pullers.
wow, a million ga zillion settings... my kinda box. where do i sign up lol... Dieselnut is trying to get me to go the tst route which is starting to look pretty damn good right now.
thanks for the heads up!
