Newbie with a ? about High Idle feature
Old Sep 28, 2006 | 12:05 PM
Dan Apple's Avatar
Dan Apple
Default Newbie with a ? about High Idle feature
I have an 05 CTD with the automatic... I have heard that my truck already has this feature... how do I use it? and is it already enabled?
Old Sep 28, 2006 | 12:50 PM
Drew's Avatar
Drew
Default RE: Newbie with a ? about High Idle feature
to tell if it is enabled, with the truck running and in park, turn the cruise control on, push set, if the RPM's jump to 1000 then it is already enabled, pushing accel will increase RPM's 100RPM, decel will do the same down.
if nothing happens then you need to have it enabled and the dealership can do this for you.
Old Sep 28, 2006 | 01:02 PM
steve05ram360's Avatar
steve05ram360
Welcome to DF...
We have a "Roll Call" thread going if you'd like to introduce yourself there... have a look.
Old Sep 28, 2006 | 01:12 PM
usafr's Avatar
usafr
If its not already done, I beleive your dealer can do it. With my Bully Dog I have the option of enabling it.
Old Sep 29, 2006 | 07:00 PM
MTRam's Avatar
MTRam
FYI: Dodge says the idle control is not available on the manuals, but there is a feature known as auto idle and I just recently had mine enabled. When it gets below a certain temp, say 20, then the auto idle kicks in and runs about 1k rpm until shut off. Pretty interesting feature if you can't use the idle control like Drew is talking about.
Old Sep 30, 2006 | 02:12 AM
NickBeek's Avatar
NickBeek
You can use the manual idle up feature with the manual transmission. You just need to either buy a clutch switch kit from Cummins or Dodge (cummins is cheaper), and have it enabled.
