cp3 pump and turbo
Old Oct 17, 2006 | 12:01 AM
hummincummins05's Avatar
hummincummins05
Default cp3 pump and turbo
i been hearing that the tst is good for tons of power and also for frying the turbo and buring the cp3 up aney body know different i know some of u guys have it aney problems i also bepends if u use sence and domt run on 6+6 buut what do u all think
Old Oct 17, 2006 | 10:17 AM
Drew's Avatar
Drew
Default RE: cp3 pump and turbo
I havent heard of any CP3 problems with the TST. I know from the added fuel to the engine it will drain the rail quite easily, but a pusher pump solves that problem quite easily.
now the turbo on the other hand will catch hell if your now carefull. I'm currently running 4/3 and my clutch is not agreeing with me when I lay the hammer down. as long as you dont bark the turbo all the time and run low numbers (below 4/4 for manuals and 3/3 for the auto) there wont be a problem. now you can run above those numbers for short bursts, but be carefull when you do or you will most likely leave pieces of your tranny on the road.
