Reverse alarm
Old Oct 26, 2006 | 09:55 PM
prattrail's Avatar
prattrail
Default Reverse alarm
Does anyone know a way around the mandated reverse alarm on an 04.5 2500 DC? You know, the one the blows your horn when you back up to a trailer with your door open? Dealer is of no help on this one, claims the Fed mandated it and he won't remove it. I managed almost 2 years without this BS.
Tyler
Old Oct 27, 2006 | 03:32 AM
ramtradxb's Avatar
ramtradxb
Default RE: Reverse alarm
How about a line off that which goes to the backup lights, that powers a relay in the wiring to the horn, so that when you put it in reverse, the lights come on and the power to the horn goes off. (unless you think you'll need to honk the horn some time while in reverse...then you'd have to put a switch in so you COULD honk the horn should you need to)
All this seems to be a pain - so I'm learning to live with the honking - and when I forget my cursing is louder than the damn horn anyway!
Old Aug 9, 2007 | 04:49 AM
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: prattrail
Tyler
This should work, it will flash the two 1156 bulbs instead of honking the horn in reverse.
The reason for the bulbs is to make the computor think the horn are still conected so you don't get a open circut code.
[IMG]local://upfiles/56817/076D0C2B95D841F38B0427E7BD719181.jpg[/IMG]
Old Aug 9, 2007 | 10:17 AM
cosmojoe's Avatar
cosmojoe
easy way is to buckle the seatbelt behind you then when you backup no horn very cool just went through this the first part of the week
Old Aug 9, 2007 | 03:32 PM
bert0168's Avatar
bert0168
I told my dealer I didn't want it turned on and they left it off. Makes me think that "mandatory" is BS
Old Aug 9, 2007 | 06:23 PM
speakle's Avatar
speakle
By far the best idea I have heard so far is to simply switch the door pin wires, front driver side with back drivers side. This way everything still functions as it should, its only 2 wires and the only negative effect would be that the honking will still happen if you leave the rear door open but who does that anyway.
Old Aug 9, 2007 | 07:31 PM
rausch42's Avatar
rausch42
that does sound like a reall good idea i think im going to try that on mine the honking drives me nuts
Old Aug 9, 2007 | 11:36 PM
speakle's Avatar
speakle
Door Trigger see notes - each kick or cluster, lrg gray plug
Notes: The LF door is purple in pin 1. The RF door is purple/white in pin 4. The LR door is purple/orange or purple/gray in pin 2. The RR door is purple/yellow or tan/yellow in pin 3.
Old Dec 3, 2008 | 01:50 PM
dhbgl1800's Avatar
dhbgl1800
Where is the plug located? I have tried everything else and nothing works except closing the door latch.
Any pictures?
