fluid capacity
Dana 70
Application: 2500 HD, 2500 HD 4x4, 8.0L V10 and Diesel w/Auto
Transmission.
Capacity: 6,500 lbs
type Full-floating
Ratios 3.54, 4.10
Ring gear diameter 10.5"
Ring gear face width N/A
pinion mounting overhung
pinion shaft diameter 1.75" inner
1.25" outer
Differential pinions two
axle shaft material Induction Hardened
diameter at bearing none
axle spline pitch 1.375"
Spring Centers 43.26"
Fluid capacity (2/4WD) 7.0/7.8 pints
wheel bearings Tapered Roller
Dana 80
Application: 2500 HD, 2500 HD 4x4, 8.0L V10 and diesel w/Manual
Transmission.
Capacity: 7,500 lbs
type Full-floating
Ratios 3.54, 4.10
Ring gear diameter 11.0"
1.25" outer
Fluid capacity (2/4WD) 6.8/10.1 pints
Transmission.
Capacity: 6,500 lbs
type Full-floating
Ratios 3.54, 4.10
1.25" outer
Dana 80
Transmission.
Capacity: 7,500 lbs
type Full-floating
Ratios 3.54, 4.10
1.25" outer
Dont know the capacities but if you follow the merry christmas thread at the top of the forum, it'll take you to a spot where you can download the manual which will have all the info you need.
i am pretty sure that you do not have Dana axles. Your truck has AAM axles. The rear is an AAM 11.5 and the front is AAM 10.5, i think. I just fill up the diffs until it reaches the fill hole, so i am not sure about exact capacities.
