which intake set up
Old Nov 5, 2006 | 08:59 PM
mopar98's Avatar
mopar98
Default RE: which intake set up
Alot of people say K&N flows too much causing dirt to get by. So I put on a pre filter.
I got immediate results in power and fuel economy[sm=signs003.gif]
Old Nov 5, 2006 | 09:05 PM
racer9's Avatar
racer9
If you're really frugal (cheap) like me, just get a BHAF (big honking air filter) for about $40. Basically it's a semi truck filter, all you do is remove the stock air box, and put the filter there. It fits right on the original turbo intake hose. The NAPA number is 2790
These are other numbers
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
AFE 20-40044
Carquest 87790
John Deere pmah19037
Big A 93790
Caterpillar 3i0005
Fleetrite ahr819037
Luber-finer laf2531
Fram ca6818
UNI 908
Old Nov 6, 2006 | 08:35 PM
heresdamanladies's Avatar
heresdamanladies
cool thanks and racer9 i thought about doing that a guy i used to work with just slapped on a k and n liek that on his turbo ...... but my worry was can water get in the turbo easier or anything??? thanks appreciate the help guys
Old Nov 9, 2006 | 08:55 PM
05 TURBO D's Avatar
05 TURBO D
I went with the S&B filter kit it seemed like the closest thing to the Volant kit but alot less. About $200.00 online without cost of shipping or tax (unless you live in CA or FL). They did an airfilter shoot out in Diesel Power magazine but I didn't see who won.
Old Nov 9, 2006 | 09:38 PM
steve05ram360's Avatar
steve05ram360
thats pretty slick looking, how does it perform?
where does it draw its air in from?
Old Nov 10, 2006 | 10:55 AM
05 TURBO D's Avatar
05 TURBO D
It performs pretty good. The first thing I noticed was the turbo spools up faster and I think my fuel economy would go up If I didn't like hearing the whistle of the turbo. It draws the air from the stock location but the opening is larger than stock. I was thinking of trying to mod up a ram air system similar to the Volant (volant draws air from stock location but also has a optional scoop mounted to the bottom) system but I don't like the idea of the scoop being so low to the ground.
Old Nov 10, 2006 | 01:34 PM
steve05ram360
I could see where that could be a problem... this morning I had to drive thru 3' of water that had pooled over the road from a busted water line.
