truck won't start
Old Nov 4, 2006 | 07:17 PM
TexasRebel's Avatar
TexasRebel
Default truck won't start
Got a 95 3/4 ton cummins started it up the other morning just fine but after a few minutes it died and wouldn't start again.
All it does now is just turn over and every once in awhile it might try to crank,any help would be much appreciate the help.
Old Nov 4, 2006 | 07:25 PM
steve05ram360's Avatar
steve05ram360
Default RE: truck won't start
welcome to df... have you swapped out the fuel filter lately? no fuel would be my 1st guess... fuel pump, fuel pump relay etc...
Old Nov 5, 2006 | 12:13 AM
jakebrake's Avatar
jakebrake
bingo fuel. Spin off the fuel filter cap and see if there is fuel in there.
Old Nov 5, 2006 | 01:12 AM
DieselDemon's Avatar
DieselDemon
Def check fuel first. I'd crack the line going from the fuel filter to the Bosch pump. Then push the lift pump plunger and see if you have fuel.
Check the shut off solenoid for movement.
Keep us updated, please.
Good luck.
Old Nov 7, 2006 | 10:26 PM
TexasRebel's Avatar
TexasRebel
!!!!!Thank God!!!!!
It was just the fuel filter this time.
Thanks for y'alls help.
