Best ANTI GEL for us CANADIANS
Old Nov 6, 2006 | 02:31 PM
kingdog's Avatar
kingdog
Default Best ANTI GEL for us CANADIANS
I use Lucas brand lube in every tank now, but with my new and die hard dedication to the running of the Lucas Brand Lube in each tank , which anti gell will work best with the Lucas Brand Lube.
I know in my 02, I was not running Lucas as much , and we Canadians did not have the new fuels out when I had it, now with my new 2007 5.9 I am wanting be sure and use it.
Thanks
Ralph
Old Nov 6, 2006 | 02:38 PM
GOD RAM IT's Avatar
GOD RAM IT
Default RE: Best ANTI GEL for us CANADIANS
I was going to use the white bottled power service additive.
I actually should start using it. My truck has started to idle at 1K, which means the temp is low.
Old Nov 6, 2006 | 02:45 PM
kingdog's Avatar
kingdog
ORIGINAL: GOD RAM IT
SORRY BUT , ??????
What is "white bottled power service additive" ??
Ralph
Old Nov 6, 2006 | 02:47 PM
ramtradxb's Avatar
ramtradxb
RAM IT - what temps are you at for any length of time that has you idling higher?
Old Nov 6, 2006 | 02:58 PM
steve05ram360's Avatar
steve05ram360
white bottle of Power Service Diesel (PSD) has the anit gel in it for the winter months.
Old Nov 6, 2006 | 03:05 PM
kingdog's Avatar
kingdog
ORIGINAL: steve05ram360
Looks like great stuff, however there is ( or at least it looks that way ) no dealers in Canada for it that I can find, BUT I will keep on looking up here.
Just had a brain _ art , I will be leaving for a drive to Miami this Sat, Can I pick this up in truck stops, or is there cheaper stores to look in for it.
And how much is require per tank, in other words if I bought a case or so , aprox how many tank fulls would I get use of with the corect mixture, and 1 more question, I guess I do not need to run my Lucas when I have this in ??
Thanks Ralph
Old Nov 6, 2006 | 03:14 PM
steve05ram360
walmart is a great place to get it. $15 bux (US) for it down here for a 96 oz jug.
Old Nov 6, 2006 | 03:21 PM
kingdog's Avatar
kingdog
Opp's I see you replied before I could finish my edit, but hey thanks, I will look in some Wallmarts on the way down.
Ralph
Old Nov 6, 2006 | 03:26 PM
steve05ram360
your best bet is to get 2 32oz bottles and when they are empty, you can re-fill them each with 16 oz PSD and 8 oz of MMO and have it ready to go. once it's mixed, just dump it in the tank and your on your way. that way your not fiddling with it at the pump.
Old Nov 6, 2006 | 03:29 PM
jakebrake's Avatar
jakebrake
Am I the only one to see the humor in that
