Wheels and Tires
Old Nov 29, 2006 | 03:19 AM
boostyme's Avatar
boostyme
Default Wheels and Tires
I know it has been talked about before, but I am too lazy to try to find it. I have a 06 CTD2500 4X4 and I am in the market for some new 20's with probally Nitto's Grapilers (sp?) I saw a guy that has the same truck as mine and he put some 20's with the Nittos and he did not have a leveling kit or any lift for the matter. The truck looked great and there was clearance all the way around with no rubbing. However, I dont know the tire or wheel width. I know he either had 305' or 315's and I believe they were on a 9 inch wheel....but I dont know if they were 50's 55's pr 60's. Long story short, I am clueless, cant you tell!....furthermore, while I am at it....does anyone know what type of offset I need too?
Take Care and Thanks for any help in advance!
Old Nov 29, 2006 | 03:46 AM
spfd308's Avatar
spfd308
Default RE: Wheels and Tires
I've been looking at wheels and tires also so this is what I've found out. Stock wheel is +40 mm offset with 6.25" backspacing. From what I've gathered you want 5 to 6 inches of back spacing to keep the tires tucked in under the fenders. Most all of the tires I've found that are in the metric sizes are usually 325/60/R20. I'm also adding a 5 inch lift so I'm not worried about rubbing issues with the backspacing too much. If you don't lift it and put the wider tire on I think there will be rubbing at full lock. Could be wrong and someone may chime in to correct me.
Old Nov 29, 2006 | 04:32 AM
GOD RAM IT's Avatar
GOD RAM IT
305s will fit no problem with no lift. 5" back spacing is what I would go with.
I have heard of some people fitting 315s with little to no rubbing but I know I wouldn't be able to swing it on mine
Old Nov 29, 2006 | 04:54 AM
JT824Megacab's Avatar
JT824Megacab
I have 315/70/17 on my stock 06' megacab CTD 4x4 and they dont rub. I do have aftermarket wheels 17x9
Old Nov 29, 2006 | 07:58 AM
ramtradxb's Avatar
ramtradxb
Had 305-R50/20's on my previous - no rubbing with no lift on a 4x4. They were a little larger diameter than 32's, but not quite 33's. But they did extend past the fender a little - backspacing was 12mm if I remember correctly.
Old Nov 29, 2006 | 01:21 PM
boostyme's Avatar
boostyme
Thanks a Ton Guys!.....I dont really care if they come pass the fenders a inch or so I am just worried about them rubbing on the inside. I am so paranoid because no one around me has these wheels and for the most part they dont have much of a selection period. Therefore, I am going to order them off line or ebay them and I dont want to get screwwed!
Thanks Again!
Old Nov 29, 2006 | 02:45 PM
ramtradxb's Avatar
ramtradxb
By the way - what I should have said is the backspacing off-center was 12mm - they rate those by centered being zero, and the positive (or negative) number being the amount it's offset from center.
