What's your next mod?
Old Nov 29, 2006 | 08:40 PM
steve05ram360's Avatar
steve05ram360
Default What's your next mod?
considering a fuel cooler... did some research and found that the filter assembly has a built in heater. fuel temps between 45 & 75 and the heater kicks on. thinking of putting a switch on it to force it off and doing a fuel cooler install. Where I live, overnight temps get into the 30's for the most part so leaving it in the on-position to heat the fuel in the morning would be a good thing. I can flip the switch and turn the heater off once the temps pick up during the day.
the cooler would be mounted near the inlet side of the filter assembly and would have to have a fan & ducting on it.
ok, there's mine... who else has one?
Old Nov 29, 2006 | 08:46 PM
Mayfair's Avatar
Mayfair
Default RE: What's your next mod?
After being here I have a TON of mods that I'd like to do, but I'm going to start with the FAAS lift pump. then the trans pan, and after that prob some differential pans. Probably some gauges in there somewhere as well.
You guy's are killin me ...
Old Nov 29, 2006 | 09:26 PM
sharx ram's Avatar
sharx ram
Only because we care Mayfair hehehe
Old Nov 30, 2006 | 12:08 AM
sharx ram's Avatar
sharx ram
Besides...its all Steve "O"s fault....if we didnt have to keep trying to keep up with him...geeze [sm=bling.gif]
Old Nov 30, 2006 | 12:56 AM
jakebrake's Avatar
jakebrake
First up is a manual trans, secound is a fass system.
Old Nov 30, 2006 | 02:46 AM
dtb86001's Avatar
dtb86001
My 2500 cam with the smallest mirrors ive ever seen on a truck. tomorrow im getting the fold out trailer tow mirrors. Hope they reduce the blind spot a little. i about crapped my pants yesterday when out of the corner of my eye came a 76 linclon. the blind spot in the 06 is way bigger than the 99.
Old Nov 30, 2006 | 03:00 AM
Local Yokel's Avatar
Local Yokel
spray in bedliner. Just did the tonneau cover so thats about it ..
Old Nov 30, 2006 | 03:06 AM
dtb86001's Avatar
dtb86001
has anyone tried the roll up bed covers. I would like to get something that will keep the luggage dry on long trips and then roll up or something when we haul the quads to the dunes.
Old Nov 30, 2006 | 03:41 AM
steve05ram360
ORIGINAL: sharx ram
bling bling??? humm coming from a guy who has a hood, smoked headlights, real shiney rims (DOH! same as mine) and fancy striping on the bed... [sm=icon_stickpoke.gif]
However, with my truck... it goes as much as it shows... it's off road often enough and it gets pounded on almost daily. [sm=gears.gif]
Old Nov 30, 2006 | 03:53 AM
Local Yokel
ORIGINAL: dtb86001
The one I bought is made by Access and it rolls up when you need to use the bed. It rolls up to the cab and has straps and clasps that hold it up there. It also has the Velcro down the sides instead of buttons, im extremely happy with it ..
