rough cold start
Old Dec 10, 2006 | 03:22 PM
jakebrake's Avatar
jakebrake
Default RE: rough cold start
Cam sensor is about $170 and they go out often (usually owners keep an extra on hand) there is a relay for the glow plugs in the valley, check that out and see if its working. Then take an amp clamp and measure the amps going to each bank (all glow plug wires) have some one turn the key on and measure it. Should be 35-60 amps on each bank which mean the glowplugs are fine. (check for white smoke no white smoke means glow plugs are good and the problem is probably the cam sensor)
Old Dec 11, 2006 | 02:01 AM
duneschick's Avatar
duneschick
Told him to check it out- he's driving the jeep for a while
Old Dec 11, 2006 | 03:01 AM
jakebrake's Avatar
jakebrake
Close, now all we need to do is get him to take the next step to a CTD
Old Dec 11, 2006 | 03:21 AM
20dodgeram01's Avatar
20dodgeram01
go to www.powerstroke.org ... a buddy of mine "maintain" is a moderator there.. he has a 2001 f250 platnium edition with the 7.3.. he could tell you everything you need to know inside and out of a 7.3
Old Dec 11, 2006 | 05:27 PM
duneschick's Avatar
duneschick
Sweet- have him get on there tonight. He did say if I take my six speed out and put a five speed in- I won't be able to get him outta there. Now I know what to do to keep him out!
Old Dec 13, 2006 | 04:10 PM
duneschick's Avatar
duneschick
Update- so far. truck doesn't fit in the garage and been real cold here and getting home in the dark doesn't help. He cleaned the terminals as he read that could cause the long starting nd also we learned if you have an amplifier in the truck- if it turns on before the truck starts it robs a huge amount of power. We never thought of that. But still didn't work. He's gonna pull it apart this weekend.
Old Dec 14, 2006 | 04:05 AM
jakebrake's Avatar
jakebrake
I checked on that injector strategy that cycles the injectors after key off. It's only for the 6.0 and the get the oil out because the injector pistons were seizing in their bores. Any update hunterhugh???
Old Dec 20, 2006 | 03:17 PM
duneschick's Avatar
duneschick
Broke down on us while snowmobiling- a little gas and she fired up.
Old Dec 21, 2006 | 12:56 AM
jakebrake's Avatar
jakebrake
Putting gas in a diesel???
