veggie oil - WVO
Old Dec 10, 2006 | 03:30 AM
derherr65's Avatar
derherr65
Default veggie oil - WVO
How do 12v and 24v cummins handle veggie oil?
Please assume I'm using good veggie oil in a proper two tank system. That means starting an stoping on diesel and heating the veggie oil to lower viscosity to diesel's.
Old Dec 10, 2006 | 09:29 PM
CowboyBob's Avatar
CowboyBob
Default RE: veggie oil - WVO
I'm not running veggie oil, but I am starting to run high blends of home made bio-diesel. You will need to change the stock lift pump because it just won't handle the thicker oil. It won't handle B-100 very well either. Most of the guys with a 24v CTD are putting the FASS systems on their trucks. FASS even makes one especially for the thicker veggie oil. If you do a search on Google, you should be able to find one easily.
Bob
Old Dec 11, 2006 | 03:48 AM
jakebrake's Avatar
jakebrake
I smell french fries
