Ref: Fuel Lift Pump
Ok! I am ready to replace the fuel lift pump and injectors.. I need all the info I can get. Will everything work with the rest of the stock setup? Any hidden things to concern me? The only aftermarket parts I am running currently are the computer upgrade, cold air intake and exhaust. Thanks in advance!
to replace your lift pump your gunna have to drop the tank, and while your at it you could go ahead and upgrade the fuel lines as well to a larger line. this realy wont help you mileage or performance wise, but what it will do is give you better flow from the pump to the CP3.
past that everything you are planning on doing will work with the stock components.
