how much oil are they using between changes?
Old Dec 28, 2006 | 05:11 PM
chadg2's Avatar
chadg2
Default how much oil are they using between changes?
How much oil are your cummins diesels using between oil changes? My first 3000 miles I used none off the stick, then I put in Mobil Delvac 15W40 and now with 3000 miles I'm down about 1/4 inch on the stick off full. Thanks, Chad
Old Dec 28, 2006 | 06:56 PM
Drew's Avatar
Drew
Default RE: how much oil are they using between changes?
37K on the clock and have yet to burn any oil.
sometimes when the engine gets nice and hot you'll have some oil blow out of the breather(totaly normal) if your towing.
Old Dec 29, 2006 | 12:20 AM
DieselDemon's Avatar
DieselDemon
171,000+ and all I lose is the amount over the full line on the dipstik. And that blows out the breather tubes. My motor doesn't leak any oil...........
Good luck with your ride.
Old Dec 29, 2006 | 01:35 AM
jakebrake's Avatar
jakebrake
burns/ blows out the breather 1qt to 5000miles in the winter. doesn't lose any in the summer.
