ABS Sensor
Old Dec 28, 2006 | 09:51 PM
Welder597's Avatar
Welder597
Default ABS Sensor
Does anyone one know where the ABS Sensor is under the hood? I am trying to install a speed calibrator to correct speedo after putting on 35's. Dodge dealer says it is on the rear pig but Superlift says to use the one underhood, but did not know where it is located. The truck is a 2005 Ram 3500 Quad Cab4x4 CTD with an automatic Thanx
Old Dec 29, 2006 | 11:29 AM
Drew's Avatar
Drew
Default RE: ABS Sensor
you need a programmer, or a code scanner hooked to the computer port under the steering wheel to re-calibrate your speedo if thats what your after.
Old Dec 29, 2006 | 03:08 PM
Welder597's Avatar
Welder597
I bought a Superlift speed calibrator, I am trying to find the ABS module under the hood. According to the guy at superlift it is under there some where
Old Dec 29, 2006 | 03:44 PM
Drew's Avatar
Drew
the ABS module itself is going to be either under the drivers side battery or under the fuse box.
Old Dec 30, 2006 | 12:21 AM
Welder597's Avatar
Welder597
Found the module and the proper wire hooked it up. perfect, everything like new.
Old Dec 30, 2006 | 12:33 AM
i11m10c2's Avatar
i11m10c2
Cant you take it to dealer and pay $50 and have them do it? im thinkin of doin 33,s or 35,s dealer told me there is a code for the tire size and to just get it from les shwab (the tire store) and thay could hook me up??
