X- RATED
ORIGINAL: cumminalong
Yeah, loosen all of them except the top 2.
Then loosen those and just crack the bottom with a flat head and it'll drain out nicely.
Man that is a good idea. I always started from the top and the "big gush" at the bottom. I just ordered the mag tech rear diff cover with some royal purple. Will remember this when removing the stock diff cover.
you can also keep one of the bottom bolts in, but loose so when you sneak the screwdriver in you have a controlled flow.
just be sure not to dammage the gasket, it is reusable
ORIGINAL: Drew
