air pocket in Power steering pump.how to remove?
OK I finally got around to fixing the gear box oil leak. I bought a clean (like new) used gear box from areputable salvage yard. During the installation I discovered the high pressure hose "Connector treads" to be very corroded & decided to replace the ps hose for about $16.00. Yes fluid poured out & I expected to refill it.The Problem is after everything is installed, I don’t have any power steering from the ps pump. It steers hard without the power steering pump working. I assume I have an air pocket in the lines..the manual states to replace the fluid and turn the wheels left to right and work out the air pocket. So if that’s the problem, anyone else do this. How do I get the pump to work normally again..? Thanks in advance.
That's exactly what you do.
Jack the front of the truck up and turn the ignition on, but do not start the truck. Turn the wheel back and forth a few time with the resevoir cap loose.
Tighten the cap, start the truck and turn left and right. You'll hear it stop whining (or whine less) once you work the air out.
Jack it up and run the pump while you trun the wheel left and right. The pump is filled with fluid enough where you won't do any damage. Just crank it all the way from one end to the other. It will get easier. The resevoir will foam, but new fluid settles pretty quick. Let it set for 30 mins, and do it again till you have just a small amount of foam. It will work itself out and add to the fluid level ever so slightly.
Good luck with your ride.
thanks..I'll get back on it sunday afternoon..hey DieselDemonI see you have a '96 ..I wonder if you would look at your power steering pump and the hose's that go to the gear box..I had the truck in the garage for two weeks while the parts were en route.) .I wonder if I mixed/crossed the hose's to the gear box..lol ..Could someone answer this??..On the p/s pump..does the power steering hose on the "Engine side" that come's "Out of the p/s pump" go to the gear box "Engine side"..Right side (when sitting behind the steering wheel) shoot I may have crossed the two.one is a high pressure line & the other is a "Return line" back to the pump.....thanks again all !!
ORIGINAL: TurboLion
Hope that helps. I looked in my 95' manual. I have a diesel, the hoses are opposite for a gasser. I looked in the book.
You need to pump your brakes as wellsince the power brake system is fed from the power steering pump. Air could be trapped in there as well. Also if you ran your pump dry enough times, you could have permanently damaged the pump to the point that it will never be quiet and will fail in the future.
I don't think they had hydroboost till 96 or 97. I had a 94ctd and I still have my 95' ctd. Both were vacuum boost. I am not sure that his 94 would have it.
You're right about workin the pedal though. It takes a LONG time to get all the air out of a hydro system.
Good luck with ALL our rides.
