HELP ME
Old Jan 15, 2007 | 09:38 PM
ADA B's Avatar
ADA B
Default HELP ME
2001 RAM 2500 24 VALVE WHERE IS THE TPS LOCATED
AND HOW MUCH DOES IT COST
Old Jan 17, 2007 | 11:53 AM
Drew's Avatar
Drew
Default RE: HELP ME
not sure on the cost, but it is attached to the foot throttle
Old Jan 17, 2007 | 11:59 AM
Batphreak's Avatar
Batphreak
Default RE: HELP ME
Its actually referred to as an APPS (Acellerator Pedal Position Sensor), its located on the front of the engine, above the injection pump on the right side. When you open the hood, that big black plastic cover you see on the right side of the head, the APPS is under it. It costs about $350 or so, I believe the best place to get it is from a Cummins distributor, call 'em with you Engine serial number and CPL number, thsoe are on a tag on the right side of your engine.
http://www.dodgeram.org/tech/dsl/Facts/Cpl.htm
