fuelpump presure regulation
Old Jan 17, 2007 | 07:55 AM
scardk's Avatar
scardk
Default fuelpump presure regulation
hi i´m new in here, and from denmark, so sorry for my bad spelling in englishi´m an automechanic and works with us truks daily, so i know a little abuot them, and have ben doing that for the last 8 years.
i have a problem with my 03 2500 RAM 5.9 diesel.
The enginge have ben running hard for som time now, but with no drivability problems, until it died on me a little while ago. I found out that the lift pump had died, so i replaced it with the original replacement kit. then it could start again.
now the problem is, *** following.
when i start the engine it set´s DTC P0251 (CP3 pump regulator control) right away and P0088 (Fuel rail pressure signal is above max limit) after a while. when those are set it only runs with 48-50% power. If i turn on theignition(withoutcrankig) erase the dtc´sand crank the engine for start (without back cykling the key first) it does´nt set the dtc and run´s (still noisy) wihtout lack of power and it does´nt set the dtc until i turn it off and start´s i again.
If i (with the drbIII) watch´s the fuel set point, itsays about 36000 kpaat idle speed, and the actualpresure is about 160000 kpa. I´ve messured all the wirrins, solonoids, valves, actutors, ecm, pcm and cheked for leeks in the system, and it all works according to dodge´s ownrepair/dianostics prcedure schematics.
I´ve changed the overflow vale, limit pressure valve, thefca, fuel rail presure sensor, flashed the ecm with the newest update´s, replaced the C2 wiring harnes on the ecm (had doubtabout the wirring connections). changed fuel filter.
I hope that there is anyone that have just a little ideaor clue about what could be wrong. thanks
