Pyro gauge install question
Old Jan 31, 2007 | 11:08 AM
Loydt's Avatar
Loydt
Default Pyro gauge install question
My 3500 6 speed came from the dealer with the Jake Brake already installed. The Jake Brake has a spot already tapped for a pryo gauge to be connected. Is that where it is really supposed to go? Seems like I put it in a different place on the Ford I had way back when. It sure would make the install easier if I could use it!
Old Jan 31, 2007 | 11:48 AM
Drew's Avatar
Drew
Default RE: Pyro gauge install question
put it there. . .I take it is after the turbo in the down pipe. . .if it is there, there is about a 300f drop from pre turbo to post turbo.
drilling the exhaust is not that hard, however if you already have a bung to put it in I'd say go for it
