ROKK Adjustable Timing Sensor
Old Feb 6, 2007 | 06:18 PM
Buckwheat's Avatar
Buckwheat
Default ROKK Adjustable Timing Sensor
These are only $70 and claim to give you better mpg power and torque. Anybody out there install one of these on a stock '06 CTD? I know the tone ring mod does the same thing but I'm not interested in that option. I don't want to take a chance with the engin warantee.
Old Feb 6, 2007 | 07:03 PM
GOD RAM IT's Avatar
GOD RAM IT
Default RE: ROKK Adjustable Timing Sensor
Mine should be here this week. I'll let you know what I think of it. My diablo predator should be here as well.
Old Feb 6, 2007 | 11:29 PM
handymanherb's Avatar
handymanherb
One thing they don't tell you until you get it is no cold idling, you have to start and be moving within a minute or less and it takes longer to warm up, but I guess you turn it back to stock position in the winter.
You can mod a stock one, all they do is remove the o ring and sand the o-ring grove smooth on the top so you can get some clock wards turn on it, I haven't seen the stock one as I haven't had the chance to put it in since I got two days ago, to see if they changed the bolt hole too
Old Feb 7, 2007 | 12:34 AM
GOD RAM IT's Avatar
GOD RAM IT
The only thing I saw about the ROKK tech sensors that made them knock in cold weather was if you had a chip or programmer that adjusted the timing as well. then it was adjusted too much in cold weather and if the ROKK tech sensor was adjusted down a bit you could get rid of it.
Old Feb 7, 2007 | 12:50 AM
handymanherb
Instructions that came with the unit says no idling cold, start moving within a minute and say if you get a knock with it start using pieces of electrical tape on top of each other, each piece will give 10th of a degree
Old Feb 7, 2007 | 01:38 AM
GOD RAM IT's Avatar
GOD RAM IT
huh.
I guess I will find out. I did some research on it before I bought it and nobody stated that they had those issues unless they were running stacked boxes or some wicked set up like that
Old Feb 7, 2007 | 02:02 AM
Buckwheat's Avatar
Buckwheat
Do you guys have the high speed idle feature on your trucks? Not sure when the first year this option was available to be inabled by the stealership. I always use mine to help warm my truck up quicker.
Old Feb 7, 2007 | 02:12 AM
GOD RAM IT's Avatar
GOD RAM IT
I have the high speed idle, but it happens automatically
Old Feb 7, 2007 | 02:18 AM
Buckwheat's Avatar
Buckwheat
Mine is controled with the cruse control just turning it on bumbs it up to 1100rpm. Mine will idle for 4 to 5 minutes before I leave for work. Hopefully this will not be an issue with installing the sensor.
Old Feb 7, 2007 | 02:24 AM
handymanherb
Guess we find out togeter, I may get mind put in tomorrow, as I don't have work early, so I have an hour or two to get it done, but then again it supposed to be 45 in the morning, might be to cold for this Florida boy
