stack threw hood
Old Feb 10, 2007 | 10:09 PM
2005cummins2500's Avatar
2005cummins2500
Default stack threw hood
Some one help i have a 2005 2500 cummins and i am wantin 2 put 1 stack threw the hood on the passengers side like a pullin truckany suggestions or how too?
Old Feb 10, 2007 | 10:53 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: stack threw hood
Yikes, with todays emissions that would be hard I think. You would need all the pollution crap in there, which would then be under the hood, which holds lots of heat and would increase heat in the engine compartment.
Now, if you could do it without worrying about emissions then it becomes a little easier.
Going to move this over to the cummins section to let the experts chime in, I am a gasoline kind of guy!
Old Feb 13, 2007 | 12:11 AM
racer9's Avatar
racer9
First, you need to check your local state law. Many states require the exhaust to exit behind the driver.
If it's legal, it's pretty simple to do. Depending on your turbo, just turn the outlet elbow up, instead of down, and custom make a short pipe straight up. Then close the hood to where it hits, and thats where you cut the hole.
Old Feb 13, 2007 | 01:11 AM
moconst's Avatar
moconst
Cut a hole, and run pipe thru hole.
Old Feb 13, 2007 | 04:35 PM
bigmike's Avatar
bigmike
One thing to consider, is that, unless you run a tall stack out of the hood, you might be cleaning your windshield and roof everyday....even more so as you do some mods.
Old Feb 13, 2007 | 06:19 PM
cumminalong's Avatar
cumminalong
ORIGINAL: bigmike
Yeah, but it would look BA!
If you don't want to go high, then at least get a stack with a turn-out.
Old Feb 28, 2007 | 06:32 AM
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: racer9
There would be a little more to do.
The hood travels in an arc when it opens so you would have to have a long slot in the hood or be able to remove the stack before opening the hood.
Geometry101
Old Feb 28, 2007 | 11:39 AM
Drew's Avatar
Drew
that is whem you have a slightly larger section of pipe secured to the hood, then the actual exhaust off the turbo would just feed part way into this section giving you the look.
however you do need to check with the local laws amd see if it is legal
