How much will the transmission hold
Old Feb 17, 2007 | 10:09 AM
samuk's Avatar
samuk
Default How much will the transmission hold
Purchased a 2500 cummins 2006, starting to prep it with chips etc. Just bought the TST.
How much will the transmission hold before serious damage, no towing, no loading, pretty much cruising most of the time.
tks
Old Feb 17, 2007 | 11:47 AM
cumminalong's Avatar
cumminalong
Default RE: How much will the transmission hold
From what others have experienced with the TST, you can't go higher than 3/3 with the auto and 4/4 with the stick.
The auto can only hold up to about 65-70 more HP before it starts having issues.
The clutch on the manual is good to about 800 lb/ft.
Old Feb 17, 2007 | 05:01 PM
cookie_monstr's Avatar
cookie_monstr
IF U GET THAT (SORRY TO BUT IN) TC LOCKER, ( 1.WAT DOES IT DO?) WOULD U BE ABLE TO HANDEL A BIT MORE? I KNOW IF U GET THAT TRANS PRESSUER PLATE THING U DEFF COULD. BUT BY HOW MUCH. SOME COMPONIES SAY THEY HANDEL UP TO 25% MORE TORQUE.
Old Feb 17, 2007 | 05:12 PM
cumminalong
ORIGINAL: cookie_monstr
I'm trying to interpret this...
Are you talking about getting a new torque converter (TC)?
Or are you talking about a new valve body, which increase the pressure and shift point?
Ideally you would want both. Normally, if you get a trans rebuilt from someone like ATS, Suncoast, BD, etc., you are getting the whole shebang.
Some of them add billet pieces (like the input shaft), a 3 or 5 clutch TC, new valve body, stronger bands and planetaries.
A good TC will bring your auto's capabilty from 700 lb/ft or so, up into the 1400 - 1600 lb/ft range.
Then your weak point becomes the input shaft and planetaries.
It's all a balancing act....but, I guess you gotta break it to really justify an upgrade.
