Power Steering Pump Replacement
Old Mar 6, 2007 | 08:40 PM
FroneDaddy's Avatar
FroneDaddy
Default Power Steering Pump Replacement
I know that there are already quite a few posts on this topic already but I haven't found what I am looking for, so forgive me if I overlooked it. I have an '03 2500 6 speed, CTD. My power steering pump needs replaced. I have been wrenching for a long time but this is one that I have never done before. Has anybody ever did it before or have any pics? I also understand that once the new pump is on that the system will need to be bled. I have bled brakes several times but not sure how to bleed a power steering system. Anyone's input on the whole process will help, thanks.
Old Mar 6, 2007 | 08:53 PM
cumminalong's Avatar
cumminalong
Default RE: Power Steering Pump Replacement
FroneDaddy, Welcome to DF!
Bleeding the system is no big deal. Once you get it installed, just raise both wheels off the ground, fill the resevoir and work the wheel back and forth. Do that until you get no more air coming out. Then start the truck and repeat. It'll make some noise while you're working the air out, but no big deal.
