help code P1689
Old 01-02-2009, 09:33 PM
jtbrian's Avatar
jtbrian
jtbrian is offline
Nope!!
No luck, drove into town drove fine, came back out of the store and turned the key on and the "check engine light" wouldn't go off so I checked with code reader and same code P1689. Cleared codes drove home did fine.
Still don't know, if there is any more sugestions please feel free
Thanks (MORE MONEY I guess!!!)
Old 01-05-2009, 12:43 PM
westwoodspeedster's Avatar
westwoodspeedster
westwoodspeedster is offline
Well i just orderd a vp44 hope its the problem, if not ahh.. i supose it aint gonna hurt nothen but the wallet. Ill let ya know how it turns out in a couple days
Old 01-07-2009, 06:33 PM
jtbrian's Avatar
jtbrian
jtbrian is offline
Could my edge product cause the symtems that I have described ( code P1689)?
If so how do you remove the system correctly?
Old 01-14-2009, 02:55 PM
westwoodspeedster
My truck did the same thing. replaced the injection pump the other day.. no more problems for 3 days now YAY!! wallets allitle lighter too!!
Old 01-14-2009, 11:33 PM
jtbrian's Avatar
jtbrian
jtbrian is offline
That is great!
Did your truck also only have the one code P1689.
When I had my injection pump replaced it still did the same thing.
Hope I don't have to replace it again..........
Old 01-15-2009, 05:34 PM
westwoodspeedster
My truck had the 1689 and 1693 witch im told is just saying the 1689 exist in the computer and is nothin to pay attention to.
I replaced both my lift and injection pump. just went with the ddrp fass pump and stocker injection. When i orderd the pump i made sure it came with a new upgraded ecm. some places i called just left the old one on and shipped it out. kinda if it didnt need replaced why fix it mato. hope you get it runnen hate to pass a fellow cummins
Old 01-21-2009, 11:54 PM
jtbrian's Avatar
jtbrian
jtbrian is offline
It has been a few days, how is your truck doing after the new pump?
Old 03-09-2013, 09:35 AM
CRosner's Avatar
CRosner
CRosner is offline
I just changed my vp44 and my truck has this code still
Old 03-11-2013, 12:23 PM
Jigabop's Avatar
Jigabop
Jigabop is offline
have you cleared the code?
also you did not put in a used vp44 did you?
Old 08-15-2013, 02:02 PM
Tcwbillmorgan's Avatar
Tcwbillmorgan
Tcwbillmorgan is offline
Dealing with the same issue truck has 79,000 miles all the grounds are good I checked the wires between the injection pump and ecm all ohm'd out fine. The thing that helped the most is I hooked up the cummins go no go box to the injection pump before I went and spent the money on the pump and it tested out fine. The issue was a bad ecm what can kill the ecm is if you arc'd a battery cable or if you have ac voltage "mine was a battery cable" ac voltage coming from your alternator my ac voltage was .01 if it is higher than .1 you have a bad alternator,ecm and just hope it didn't get the computer on the vp44. This can be tested by placing a volt meter on the driver side or passenger side battery start the truck check for DC voltage and make sure it's charging then turn your volt meter to ac voltage still hooked to the battery. This will tell you if you have ac voltage feeding back.
Quick Reply: help code P1689
